First of all, are you sure your multimeter is on the right setting? Also, the pins could be somewhat dirty. They should read 10-14 ohms if they're good. You can put 370CC injectors in, but you'll need an upgraded ECU with revised fuel maps to compensate for it, or your car will run very rich.
